Does anyone in the Tampa or Central Florida area get the new box with a remote thats has a finished black front and silver back and side....what will the new purple D button be used for?
I'm certain they designed the box intentionally so that removing the card breaks the box. It could have been designed so that was not the case, but they didn't want to play nice. Why have something that plugs into a slot connector, but can't be removed? Insanity. In my mind, that makes it not removable. Is your heart removable? Sure it is. So do you believe you have a removable heart? Same thing. Remove it, and what is left behind is non functioning. But you can still call it removable if you want to.
steven, correct me if i'm wrong, but i thought one of the points of the nex box........it was suppose to cut down on cable tv theft. i thought i had read that somewhere.
steven, *I* wouldn't want to remove it; but that's not the point.
The point is, the law says make it removable. Now I know you don't like the law, so is it OK to disobey it? Actually, I guess after all it =is= technically removable--even though before you said it broke the box. Now you say it doesn't. But it costs you $500 if you do, plus screwed down, plus sticky sealed. A $500 charge to reprogram the card. Yeah, that's reasonable.
The government wants it removable so you can take it out, put it in your own STB, and receive the cable channels. It is that simple. Customer choice of box.
So the bottom line is that the cable companies have found ways to circumvent the intent of the rule, viz., make it technically removable, but so difficult and expensive to so so that no one will.
