I also checked mine last night, and I do have a 15 degree on the LNB arm (in back of the dish), so I know that the dish is set up correctly. I checked both the latitude angle on the motor, and the elevation angle behind the dish, both are where they are supposed to be. (43.2 and 23.3 respectively).
I aimed to true south, set up the Viewsat screen to read for 79W, TP 12177 @H20500, and the motor moved ever so slightly, still no signal, only 'S' of about 45 or so.
Moved the dish up and down, left and right (slowly), nothing!
I think what I will do is switch the lnb over to a circular, and try and pick up Nimiq2 at 82W. (stronger signal)
I will set the Viewsat to go to 82W (instead of 79W) from true south and hunt for that signal first.
If I find that, maybe then I can go to the other end of the arc and tell the motor to turn to 110 or 119. If I find one of those, I should have a decent arc started.
I am hoping that another Viewsat Extreme user can chime in and tell me some pointers on this receiver? I have a few questions.
