"no signal"
Purrington
4
New York State
I have a problem receiving a Satellite Signal from my Direct TV Dish.
I have checked all cable connections.
I have unplugged and replugged all connections making certain they are secure. In doing so I left connections unplugged for a couple of minutes before replugging them.
I have reinserted the Direct TV card and pressed the "red button" to reboot.
When I do this after about a minute I get "Searching for Satellite Signal" and in a short time I get "Receiving Satellite Info..." [0% Complete].
It stays in this mode for a few minutes but no percentage of the satellite signal is ever received. Then the screen momentarily goes to "No information Available" and then turns black.
For a few days prior to actually losing my Direct TV signal I experienced a number of episodes where the image on the TV Screen would "Crack Up" or "Freeze."
Could anybody please tell me what other steps I might take to correct this problem?
Thank you
~Purrington
Can you get to the menus to see what your signal strength is ?
I would start with determining if it's a alignment issue first.
No Signal
Jimbo:
I am sorry but I do not know how to get to the "menus" to determine the signal strength.
If you would instruct me on how to do this I will do so.
Thank you for both your response and your help.
~Purrington
No Signal
Satellite Transponder 32 Total at 101 degrees.
Azimith 233 degrees; Elevation 31 degrees, Tilt 64 degrees.
1-8 52, 0, 51, 0, 50, 75, 47, 73
9-16 40, 0, 51, 0, 50, 75, 0, 75
17-24 0, 81, 48, 0, 47, 74, 46, 72
25-32 50, 54, 50, 0, 54, 74, 48, 75
Signal Strength = 54%
Satellite 101 Degrees; Transponder: 1
Jimbo: I hope this is the information you need.
Thank you
Purrington
Thank you
Purrington
Do you have the Protection Plan ?
If so, Call D* and have them send out a tech to re align your dish.
Questions about coming back?
Direct tv extentions question
