hzhao said:I got two 811, one of them got the update and the other did not, Uh.......... Anyway I can force it to download?
gpflepsen said:yup, that fixed it.
Bobby said:Just as I figured.Now since my last input, I've decided to match you Gerry. I was on OTA for a while, went to satellite, bam! the blackout. I needed the hard reset too!!!
Here we go again.....
zoomer said:Recall still does not work, .
zoomer said:Recall still does not work, still get searching for signal while watching OTA and using the guide. No change on my SD display, but mine was not dark before. Picture on component looks brighter. OTA channel locking seems much better.
BFG said:The Recall does not work... Are you sure you're talking about the right recall?
Were talking about watching an OTA Channel then recalling to a satellite channel, or any other channel for that matter
Was the OTA channel mapped with PSIP data when you tried it, cause that was one screwy thing that I noticed that does work. For some reason the channel will work when there is no PSIP data on the channel (as one of my locals happens to be that way)
but did you notice that unless you're using either the "all chan" or "all subs" favorite lists that you can't go to a channel (with the keypad) if that channel is not in the "fav" list that your currently using?GaryPen said:OTOH, the highest number no longer is invisible.......
new_to_hdtv said:but did you notice that unless you're using either the "all chan" or "all subs" favorite lists that you can't go to a channel (with the keypad) if that channel is not in the "fav" list that your currently using?
