Yes, multi lnb just needs a DiSEqC switch. Put it after the motor.
Receiver > Motor > Diseqc Switch > LNBs
last night i have seen the light flicker and the display on the motor was not showing all digits properly. I assume/hope its the motor. seller will be sending me a new motor.Sorry to hear you are having that problem. It sounds like a short or possibly an overload? Have you tried running a different coax cable to the motor? Are you still using the Skytech ST-19200 - wondering whether it can supply enough power to run a motor?
Hopefully just a bad motor. Glad the seller is taking care of things. Good luck!last night i have seen the light flicker and the display on the motor was not showing all digits properly. I assume/hope its the motor. seller will be sending me a new motor.
still using the Skytech ST-19200.
Running another coax cable would be a real pain. it is routed from back of the house, through the attic and dropped in to the livingroom. It is 55ft long.
Thank you.Hopefully just a bad motor. Glad the seller is taking care of things. Good luck!
Hello,
I am new to the forum and have several questions if I may;
I live in SE coastal NC.
I purchased a European receiver which it has pre-installed Satellites that are not accessible from NA.
I have an existing DP 3 lnbf set up.
My questions:
Can I download NA satellite list and upload it via USB to the receiver.?
Is it possible to use DP set up for fta?
I also have an fta Ku band lnb I can install.
Please see images for the receiver and the dish.
Thank you for your help in advance.
He already bought a 39" dish:First, get rid of any DishNetwork equipment. There is no FTA on DishNetwork and the dish is a little undersized for reliability and gain from most satellites / transponders. Get the 3 foot KU dish and your motor and after getting it setup and peaked you will be a happy camper!.
Problem is now with motor: "last night i have seen the light flicker and the display on the motor was not showing all digits properly. I assume/hope its the motor. seller will be sending me a new motor." Seller is replacing it.Finally, It's alive!! BUT! Got my 39'' dish and motor. My receiver is Diseqc motor compliant which is a plus. Got one problem though, the motor shuts off my receiver. when i disconnect the coax cable to the motor the receiver comes back on. Anyone has any idea why would that happen? I did reset it. I got great channels but when the motor switches off all goes away and when it says motor turning it actually not.
It is a shame, but we all run to some people like that time to time unfortunately.Shame the seller decided not to take responsibility - not a good way to do business. Which receiver are you considering?
Yes, that's the one I use. I think you will be pleased with it.It is a shame, but we all run to some people like that time to time unfortunately.
I have decided on Amiko Hd Se mini. It should be plenty to do what we are looking for.
