Yep signal went up 10 -15 accross the board.Hemi has anyone done a before and after comparison with the reflector swap? If so could you or someone here post their results.
Also was any drilling required to get the reflector to fit?
Bob
95% of the time they return on their own.
Sometimes I might have to change the channel , but I can't recall ever doing a reset or reboot.
I had 2 Techs Peak the 1000.4 and neither could do it justice, against premature rain fade.
The Tech installed the 500+ refelector.
So only thing I noticed was the reflector and the reflector mount was changed, No drilling!
And the LNB arm and Mast stayed installed the during the whole process.
So the Plus Dish Reflector solved that!.
Thats the same problem I've had here and 3 techs have tried to align it. Yesterday was the last attempt he relocated the dish from the roof to the side of the house so I can reach it in event of snow. He got a little extra signal out of it too but really not alot more.
We'll find out how it is during the next rain or snow storm. The Jury is still out here. But I will say the tech did a great job so I can honestly say he did his job with what he had to work with.
Would be nice if I could get my hands on a 500+ reflector. Maybe Dish can create a "upgrade" kit for the field techs in bad signal areas.
Okay so they are sending a tech tomorrow to diagnose the problem. Whenever I have a problem I can't solve on my own or with help from members here, I contact Dish through Twitter and I am always amazed at how quickly things get taken care of (especially compared to the regular CSR's on the phone). I sent a link to this thread, a few texts back and forth and now techs are on the way . Thanks *MD @ Dish!
Is the 500+ reflector really better than the 1000 reflector? Is it heavier?
LNBF set up.
Your just using the REFLECTOR!Okay so if the 500+ and 1000+ are for those sats, how could either be used for me if I'm on 61.5, 72.7 & 77 ? I mentioned it to the tech and he also said it's just for those sats. Do you mean to just use the actual larger dish but keep the same LNB and aiming set-up?
