Hello,
I have a bit of a problem. I have searched for the answer, and have came across a few possible answers. Last week I installed a DP34 switch so I could run multiple receivers. I have a Dish 1000 and a VIP 211. I need the switch so I can feed the 211, a 622 and a 301. I currently only have the 211 activated so I cannot test with another receiver.
My problem:
I am losing signal when changing channels. I actually lose transponders. When I installed the switch, I installed it per the directions, both cables off of the twin to the first two inputs, and the 129 feed to the third. I ran a check switch, and everything tested fine. Later that night, I tried to listen to the Sirius Channels and noticed that the receiver was searching for signal once the channel was changed. I ran a switch test again, and it showed everything working correctly. So I took the cables loose from the switch and checked that they were tight and re-installed them. I then ran another switch test, and everything seemed fine. Two days later, it started happening again. I am using new RG6 Coax ran from the switch to the junction in my home. From the junction to the receiver is RG 6 also. It was installed in the home when we built it in 2001. Until I added the switch, everything was fine. I have a problem believing the switch in bad though. Maybe it is. I have a hard time believing the cable is going bad also. If I had to believe one of the two, it would be that the switch has went tits up on me. Any help with this matter would be greatly appreciated.
Thank you in advance,
B-Dub
My problem:
B-Dub
