I have two Dish 510 receivers and a Superdish with a DP34 switch. I just started
loosing the signal on my local channels. A window will pop up every couple of minutes
saying searching for signal. It stays up for a couple of seconds and then the show comes
back on. This is happpening on both receivers so I think the problem is the switch or
LNB. I checked the signal strength. The signal strength holds steady at 58 and then
drops down to 0 and then back to 58. It wasn't windy out so I don't think my dish is
moving or a tree branch is getting in the way.
I haven't checked the connections at the dish or switch yet. That is the first thing I am
going to do. Do these symptoms sound like a bad LNB or switch? Can I bypass the
switch and cable a receiver directly to the LNB to determine if the switch or LNB is
bad?
Thanks for any help.
Mark
bad?
Mark
