Keep losing signal
jonyac
25
Maine
I am new here as of tonight. I have a problem that just started. I have a TurboHD setup with a 722? receiver and it is a spare setup I use at a campground. I used it all summer and I just set it up at my sisters house for the winter. When they turn the receiver on in the morning there is no signal. I set the dish up with two RG6's on the lnb. They have to go out to the dish and swap the cables to make it work. Same thing the next morning, they have to do it again. What,s up??
Two different dishes? One at the campground and one at your sisters. If so you're system is perhaps still thinking it's hooked to the old dish.
Try running a checkswitch. Menu, 6, 1, 1. Then test.
Should be no reason to run two lines from the lnv to the receiver unless you're missing the separator or not hooked up to a pro plus lnb
Help with getting locals with antenna
Traveling with Dish Network
