Joey 2's are pixelating
Mateo125
DFW
Hello, I have a Hopper 3 with 2 Joey 2's. Recently started pixelating on living room joey, verified
the other joey in another room has the same issue with every channel. Hopper 3 is clear on same channels. Moca rates from hopper to both joeys are over 245mbps. If I reset hopper and joeys the problem goes away for a short time. Any ideas?
Could be a few things. From a potentially failing or off peak LNBF, a cabling/Connector issue, Hub/Node may have gotten water in it, non 3Ghz cable or RG59 in the host line or the Hopper itself may be starting to fail. You really need a tech to come out and take a look
Switching from two LNBF to three LNBF
H3 - HWS Comparison
