Is the multi-switch worth keeping?
FIREBIRD81
300
When they installed Voom, they installed a Winegard vm-3400 multiswitch. IS this thing compatible with other DBS's, or is it now garbage?
it will work on other dbs ( providing voom don't want it back to) it will work for sure on the single 18' D* dish for sure not sure what else you could use it for it will not work on the Phase III dish.
t
What does the Winegard vm-3400 multiswitch do. I still have the E* dish placed on the room. When V* was installed, I believe they added this switch and ran the existing cable to the new dish. When I go back, do I leave the switch and just connect cable back to the old (E*) dish. Thanks.
No you will take out the switch this switch can not be used on the Dish 500 you need the dp34 switch to hook up mult.
t
Does the dp34 do the samething that the Winegard vm-3400 multiswitch does - but is a compatibility issue? I thought that combines and seperates the OTA line and sat. line. I hope that it wont be difficult to rehook the E* dish back.
On another note, while I don't post much, I do view quite abit. I think its great all the assistance that many of the "veterans" provide, ecspecially TYORK. You guys are one of the reasons I felt comfortable switching to Voom (about 5 weeks ago).
Thanks kccody,
yes the DP 34 switch combines the 2 or 3 sat together and feed in on one line and vm 3400 switch just combines the satelllite signal and OTA together so you can see on up to 4 tvs.
How many reciever are you hooking back up on E*
t
I have two recievers plus an antenna for OTA HD. Do I use the DP34 for the two stb's and the Winegard vm-3400 for the OTA reception?
My Offers from DirecTV and Time Warner Cable
Xbox HD coming out Preview on MTV May 12
