I'm relatively new to this so thanks for your help.
I am using a single DVR-625 in dual mode for 2 tv's in separate rooms. I would like to install an OTA antenna (Channel Master 4228) in my attic so that both tv's can access the antenna signal. Initially, I had planned to simply connect the antenna to the antenna input on the 625 but then only the primary tv can access the antenna signal and only when the receiver is powered off--correct? What is the best way to connect it so that I can view it from both tv's as easily as possible? Presently I don't have any switches installed. I had thought about using a splitter (2 GHz) or A/B switch box? Other ideas or suggestions?
Thank you!
Thank you!
