Ok... my turn.... I have just installed an H20 and AT9 5 lnb. I replaced a round single lnb dish and older (10+year) receiver. my old receiver had 97 signal strenght average. My new one... has...zero.... I'm in the 98321 zip... I set the azimuth to 134, elevation to 32 and tilt to 108. zero signal strenght....I set it to zone one...(tried zone two also sinc I live under the black line on the map) I verified the port one and port two cables...(even switched them once just to see), verified that I used the red line not the black edge marker for elevation.... zero...the on screen shows nothing but rows of zero's on the first dish pointing screen and zero signal strength on all transponders... The bubble is in the middle of the circle. The dish is pointing in the same direction basically as the round one I removed. I even hooked up my old receiver which was working fine a few hours ago to see if it would get a signal from the new dish...zero signal strenght... tried switching to a differenct coax connector on the dish...no change...existing coax reads RG-6 on the cable and the run is well below 100 feet..... I'm out of ideas... what have I missed?
