If it is that big of deal buy a wing dish yourself or cancel.
Could not of said it better myself, Thank you sir WiCkeDuDe!!.....
Um.......He did get signal, If you would of read her posting. Here is what she said. Quote {I finally gave up and let the installer do the way he was ordered. When he was testing the equipment, I notice that I am getting about 50 in signal strength for both 110 and 119 but only about 20 for the 129.}
The signal screen will show around 50 or 60 percent strength due to the signal modifications. True, I will not argue that the signal is low but he did get signal!!
I did read her post. She did a simple re-boot and lost the signal altogether. If that's an acceptable installation to you, please don't ever move to Central Illinois and work on my setup.
Ok lets stop all the fighting in this thread and see if we can get the problem fixed.
First we need to know where you are located. THis will tell us if you are really in one of the areas that would benifit from a 2nd dish for 129. Some people are so gloom and doom and say that 129 is falling out of the sky and that you need a wing dish no matter what. There are area's of the country that this is true, for the most part the 1000.2 work just fine on 129.
So it really comes down to is your area an area that needs a 2nd dish, or did your installer not get the dish you have peaked? From what I have seen in the thread the dish was not peaked. 50 on 119 and 110 is low I get 73 on 119 and 62 on 110 129 should be in the 30's. So at this point let the installer come out and get the dish peaked. If then you can't get the 129 to work properly then llok at a wing dish. Thing is you will have to go with 2 Dish500's or point to 61.5 with the wing dish. If the wing dish is pointed at 129 and the 1000.2 starts to pick up signal from 129 it will cause problems.
So according to DirectDishNet, it is my fault that I can't get any signal from 129, it is my fault that the PROFESSIONAL INSTALLER thinks that a signal of 20s for the 129 is acceptable.
It is my fault that I signed the service agreement when the PROFESSIONAL INSTALLER told me not to worry about the low number for the 129 and everything is fine?
It is not the same as buying fast food, if you buy a TV, bring it home, and found out that Video 1 is not working all together, is it consumer's fault?
Exactly.
BTW, congrats Dave on 1,000 posts.
Exactly.
Dish isn't aligned, get that hack back out there. 50 is too low on 119, that's about 14 points lower than it ought to be. On the old scale, that's like 30 points.
NOT acceptable. Installer need to do the job Right! Thats what he was "PAID" to do.That's all I was trying to say - the guy didn't do a quality job if she loses signal from a simple reboot. If the power went out, her receiver would reboot when the power came back on. Is it acceptable for her to lose signal because of that?
My mistake, I thought I need a switch in order to hook up 2 seperate dishs.
Didn't realize that 1000.2 already has a LNB input.
I am not asking for a non-standard installation, all I am asking for is for Dish to provide all the channels that I am entitled to which would require signals from all 3 birds.
As of right now, I still can't get signal from 129. If the solution is to install a 2nd dish, don't you think I am entitled to one?
If DPP44 is not an option, then I will have to keep the DPP Triple right? What 2nd dish and 2nd LNBF should the installer install?
Right now I am using all 3 ports from the DPP Triple (1 port with a DPP Seperator to hook up to a 722 and port 2 & 3 are hooked to two 211)
Also, what's a reasonable signal strength level? around 50s for all 3 birds?
I used to have signal in the 90s for 110 and 119 while I was still live in Houston....
First of all you're not ENTITLED to anything. If that's the attitude you had on the phone with dish and with your installer, I can see why no one tried to help you. Good luck getting your system working.
One last question, I felt the position that the original installer put the dish is a bit too low, and a neighbor's chimney might be blocking some of the signal.
Can I tell the installer where I perfer to have the dish installed? or is it purely their decision?
My house has a 2 tier roof, I initially wanted the installer to install the dish on the higher tier but he said it will be too difficult to MAINTAIN OR ADJUST and said he would install it at the same location on the lower tier roof edge..
Also, since 129 is giving me problem, will asking DISH to install a dish 300 point at 61.5 help?
D-1000.2 supports three orbital slots. 110/119 and 129 ONLY!The best you can do is to call them back or perhaps contact ceo@echostar.com if the following does not work .....
I think the 1000.2 supports a fourth satellite location (has an extra port on it for an additional satellite slot) so a DPP44 should not be needed if I am not mistaken. The only thing that should be needed is that old dish that you have and make sure it has a DP lnbf on it.
