Hopper S208/S209 Software Release Notes
If 208 was a limited rollout and 209 was quickly pushed like this, you can be certain it is limited to the same, if not lower, number of receivers.
Not necessarily. They have had a limited "xxx" release followed relatively quickly by an "xxx+1" general release several times in the past. It's not an uncommon software practice that "xxx" is the test release and "xxx+1" is considered the production release with little or no changes.
I got 209 here last night as well.
S208 only went out to less then 5000 units as a test.
They must have seen something in S208 that caused them to halt the S208 rollout, fix the issue and send out S209.
356B said:
Huh.......?
I think the question was, how to check it remotely.....is that not correct?
Yes. That was the question. You said it was on the right in preference section of DRA. I checked that and all I see is the DRA SW version. I think Scott said he used his Sling Box HD to navigate his Hopper menu to see his SW version.
