Hopper Plus Reports Good/Bad
Seems like the Hopper Plus can be fast randomly which was why it seemed like it worked. Probably needs people from XDA Forums to have interest in the Hopper Plus. I wonder if the whole problem is with the DISH app (package name com.dish.atv.launcher) which is at version P11701.2023050212. Still amazing how they could have launch a product that has serious problems like this and using it to attract new and old customers.
I just go the Hopper Plus responding faster...
Basically, this is what needs to be done...
1) Turn on Developer Mode on the Hopper Plus
Code:
1) Press the Home button once on the DISH Remote
2) Select Settings which is the cogwheel on the upper right of the screen
3) Click on Device Preferences
4) Under Device Preferences, select About
5) Under About, select Build
6) Once Build is selected, press the Select button on the remote seven (7) times  or until it says something that says "Congratulations you are now a developer" as I forgot the exact wording
2) Speed fix
Code:
1) After you did the above, Press the Back button so you are at the Device Preferences
2) Select Developer options
3) Under Developer options, go down to the Drawing section
4) Note down the default settings under the Drawing section for Window animation scale, Transition animation scale, Animator duration scale by either writing it down or taking a photo of it
5) Select Window animation scale, select Animation off by using the up/down buttons, then press the Select button and press the Back button so you are at the Device Preferences and under the Drawing section
6) Select Transition animation scale, select Animation off by using the up/down buttons, then press the Select button and press the Back button so you are at the Device Preferences and under the Drawing section
7) Select Animator duration scale, select Animation off by using the up/down buttons, then press the Select button and press the Back button so you are at the Device Preferences and under the Drawing section
8) Press the Home button once on the DISH Remote
Test and see if things are faster.
Can someone post what the default settings for 4) under 2) Speed fix above?
This is an old trick form earlier versions of Android on phones that we'd do to make the menus not delay for x amount of time before opening, making the phone seem snappier
Except I never used it even on rooted devices as I always edit the build.prop file. The only Android device I had that was slow was the removable Tablet from the HP Photosmart eStation Printer but still not laggy like the Dish Hopper Plus is.
The Hopper Plus being on a 2.6Ghz Quad Core CPU with 4GB of RAM from the specs is supposed to be faster than the Amazon FireTV Stick 4K Max which is Quad Core 1.8Ghz and the Google Chromecast with Android TV 4K which is Quad Core 1.9Ghz , both being on 2GB RAM.
In any case, I am joining the disconnect the Hopper Plus gang and will wait until someone actually reports that is actually works after some future software update.... Until then, it's a Hopper Plus brick just for looks. :biggrin
Could you share how you did this?
You can sideload most any android app onto Android TV and most run fine. For my security camera software I had to find the APK and then used Downloader to download and install the file. Standard non Android TV apps do not show on the apps menu so use a program Sideload Launcher to launch the Video Camera app.
what Downloader app? Is it in the app store? I'm not seeing anything that just says Downloader. I see an apk downloader but it's $3.99. Same with sideload launcher. I see a sideload home and then just launcher.
I never use it either and also root my devices. That fraction of a second is barely noticeable anyway
You guys haven't seen improvements with this week's updates?
Or maybe it's not?
I'm surprised Downloader is available
Skip back/forward lag time is still there for me in the Plus & Joey 4s watching recordings.
These kind've things like lag have less to do with software and more to do with the hardware. A good example is how the Hoppers had the same issues with the GUI until the Snap came out. I have it on my Sony TV's home screen and Nvidia Sheild Pro GUI. (For the TV I need to see if I can add more RAM).
Until Memory and access to memory is improved with a more efficient way of using Swap or whatever AndroidOS uses, not fix is going to make these things better IMO
Time for new Hopper model.
The only other thing I can think of is I wonder if the lag is caused by the temperature the Hopper Plus is running at because I am sure some people who have not posted might be in cooler environments so they don't see the lagging problems so would be interesting to know what temperatures different people are having their Hopper 3's running as there had been certain phones like the LG G4 which had stability issues and lags that were fixed when the thermal interface material was replaced as a majority of the phones failed because the overheating caused one of the two processors soldering joints to melt causing the phones to boot loop as mentioned here:
I did experience the issue and LG fixed it by replacing the entire motherboard when sent in.
Does someone here have a Hopper Plus that is not made in India? If it is software, then hopefully DISH can fix it in updates without having to update to the next model of the Hopper Plus.
PPV movie “The Little Mermaid” on channel 507
Outdoor Pack?
