Which HDCP does Dish use on the Hopper 3? Is it 2.0 , 2.1, or 2.2? I have so much trouble with my Hopper 3/ 4K Joey. I want to try a high $ HDMI cable . But I want to get the Protocol being used. Thanks.
The optical works fine on the H3. I have my H3 HDMI connected to the TV and the optical from the H3 to my AVR.
What receiver are you using? I know I need to tell my Denon what to look for (HDMI-Optical) for it to process correctly.Thanks. My work around is to go from the Hopper to the TV with a HDMI. Than from the Hopper 3 to the AVR with a Optical cable. However I can't get any sound out of my AVR. Is the Optical out working on the Hopper 3. Or is that broken also? Thanks
I'm not an installer so hopefully one will provide some clarity here but if joeys are ok and 4K is not I would guess the 4k requires a higher data rate then the regular joey thus the coax (NOT HDMI) and connectors should be top notch not whatever was leftover from other systems and that may be causing your communications issue.Denon X4000. I tried a lot of stuff. Nothing made the 4K joey work better which was the goal. Has to be a software issue. Kids have two regular joeys and no issues. Mine/4K see's the Hopper 1 every 3 times it is turned on.
Just a thought...
