TEN89 said:Ok, I won't have to send anything back. everythings mine.
Be careful. When I cancelled they wanted a 6000 and 508 that I had purchased, I had to fax them the receipts before thet changed their minds.
rad said:Be careful. When I cancelled they wanted a 6000 and 508 that I had purchased, I had to fax them the receipts before thet changed their minds.
scrotus said:Trav,
As for the old dish...
5. Unless you already own a D-10, more than likely you will receive the R10 80 gig model. The retailers probably don't have any D-10s left. I like the R10 though I don't have anything to compare it to.
The only difference that is major between the 522 and the D recrs is that the 522 can output to a seperate room through coax. Also it has a second remote for independent control. It doesn't sound like you use that now. There is a way to do a back feed using the coax out of the R10. Run the coax out to your second room, then use the RCA hookups for you main tv. But then you have to figure out how to control the R10 from the other room which entails using something like an RF universal remote with RF receiver/IR blaster. I thought about this option for my house but went head and got a basic receiver for my second room.
Hope that helps.
rad said:Just so you know, the HR10-250 does not output on the S-Video or composite video out's unless it's set to output a 480i signal, if set to 480p, 720p or 1080i the those outputs are disabled.
Trav said:Okay, thanks for the info. So how do you switch the output - just a menu command? For example, let's say I did have it hooked up to my PC via S-Video and wanted to watch something. Would I just go into the menu and set it for 480i temporarily and then switch it back when I'm done? Like I said, I don't watch on the PC very often, but I'd still like to know.
jbcheshire said:I am in the same boat as you...
rad said:You can do it either via the front panel switch on on the remote, press the up arrow onthe disc and it will cycle through the different resolutions.
lovswr said:Ok I was over at my local Best Buy. 250 gets me one R10 & 3 basic receivers. What I forgot to ask is that in the form of check or just credit on my first bill? Also, since D* does not charge a per receiver charge for the 3rd & subsequent units, looks like I'll be saving about 15 a month on Total Choice +, & Locals & 4 receivers vs the Americas 180, Locals, & 4 receivers right now. Or am I missing something else?
