OTHER Help Setting up KU dish for G19
I finally was able to work on it again today, I took the dish off and put a level to the pole it mounts on. The pole was about 3-4 degrees off level. Reset the dish and accounted for the pole. Finaly got G19. Then used it as a reference for SES 3 and picked it up, but not getting the radio now...
Well, you are getting closer though...
Awesome, thank you. I thought I was going crazy. Do I have to manually enter for NBC and COZI also?
Glad to hear you are lined up now! :)
No, if the dish is pointed properly and the signal is strong enough those should come in fine during a blind scan. If not, try entering the frequency for them manually and doing a transponder scan. :)
AMIKO Need replacement for Amiko 8240
Linkbox Linkbox Channel Editor
