having trouble connecting TV, satellite receiver & DVD recorder
Dennis Eavenson
I recently had my TV serviced. I was able to watch sat channels, play DVD's & also record to DVD-R & RW's. When I got tV back to hookup I was not able to get Sat channels to record to DVD recorder. I have component cable from TV to DVD recorder & audio/video cables going from DVD recorder to sat receiver.
I also have coaxial cable going from sat receiver TV ch-3-4 out to TV antenna 2 in. I have a tech diagram of may connections. Any ideas would helpful . I am attaching a pDF of the connections.
Dennis
  • tv, dvd & receiver conn4.pdf
Not sure why you can not record but why do you feed the TV with rf ch3 or 4 when you could feed TV from sat with S/AV.
Sound like you need to check input setting on you DVD recorder
I just looked at your file again, you have the output of the sat going to the output on the DVD, move the A/V cables down to the input on the DVD.
I would also use a S cable from the sat to DVD
HD TV and OTA to Six Rooms
my 622 is becoming useless
