Standard setting..NOT Universal1.LNB Type ? I know its a universal but 1 or two. When I choose any of the universial choices it blacks out LNB Local-Freq. and 22kHz so I know I cannot change those
Depends on what port you plugged the L & C into2 DiSEqC? Off,1,2,3,or 4
Irrelevant…leave as is3? Skew... I guess I just leave at 45 or - 45..the defaults
This is how you peak the dish…If you are aiming for your true south which you say is AMC5 use one of the following (you can scroll through them)4.TP? I have not a clue what that is?????
11742 V 11110
12182 H 23000
Right now I’d leave that disable….unless you have to move it to get close to TS.5. Positioner Setting?? I think this is suppose to be USALS
edit...you're at 78.8 so you should be fine...leave at disable until you aim it first
Strength don’t mean anything. I get 70 with the LNB laying on the ground…it will go up as you get close but quality is what you needI must be close to something because my signal is at 70% but nothing on the quality level.....I have not yet peaked it
