i have a 98 ford explorer and non replay sportster. couple of years ago, had a jvc pnp and used it in a chryster mini van, i think 99. i had a fm mod for the jvc and when i turned on the unit, no matter what fm channel it was on, sirius would take over.
with my sportster, i tried using the same fm mod with an adapater to make it fit into the fm out of the sportster. however, i still have to have the fm out turned on for the unit to work and it has to be on the freq assigned by the unit. i went out a purchased a new fm mod made by sirius to see if it would be different, it is not.
my question is, does the sportster need to be set up anyway so when i turn it on, no matter what fm channel it is on, it will play? or is that the way the new units are designed?
or do i need an antenna adapter for the ford radio? the guy at best buy said no, but you know how much they know.
thanks.
thanks.
