Ok, for those of you who have been following this thread, here is a technical question.
First the parameters. I measured this dish before I put it up, and here is what I found.
The diameter is 90-1/4" (229.2 cm) from the very top of the circle angle to the other side. This is only the area that can be seen by the feed-horn.
The depth is 14-3/4" (37.5 cm) using 2 strings from the same edge as above.
The factory specs on this dish from a sheet I got from a former dealer, are:
Focal length 33.75"
F/D ratio is .375
Using the figure above and the calculator from SatLex, I get these figures:
Focal length of 34.5" (87.55 cm)
F/D ratio of .38
Why is there a difference between the measured and calculated specs versus the factory specs?
Do they know something about this dish that I don't? Or did they just do a CYA maneuver?
I currently have the focal length set at about 33.5" which puts it at about 1/4" inside the mouth of the co-rotor, because I couldn't get the support arms to reach out further. I have the F/D ratio set at .38, and that is where I currently get the best signal.
Should I make some adapters for the support arms to move the scaler ring/co-rotor out to where the calculated distance should be?
If I bend the support arms where the slots are, I might be able to get to the 33.75" specified by the sheet, but never to the 34.5" calculated length without modification. I would rather make adjustable adapters than try bending arms.
The chances of getting all four to bend precisely at the same place and the feed-horn pointing precisely to the center of the dish is very slim.
Thanks for all your explanations and answers.
Fred
Focal length 33.75"
F/D ratio is .375
F/D ratio of .38
Fred
