Dumping Motor Positions Table
zamar23
1,204
Mid West
Anyone can suggest a way to dump to a PC the default Built-in Sat Positions Table from Moteck SG2100 motor, and also saved new Sat Positions Table after positioning a few sats with the motor and sat receiver? I don't think, its Manual reflects updated complete positions list. Any PC utility for that? Or any way to use a sat receiver for that? I need correspondence btw position numbers and sat coords in degrees. Wanted to match position numbers between a sat receiver SV8000HD and a Prof card used with DVBDream.
Also, any experience in making DVBDream 1.5e to control the SG2100 motor positioning accurately via Prof 7301 PCI? Does DVBDream 1.5e have an accurate USALS algorothm now? What's the best way & sequence to use its Positioner Console?
Probably need to pull the flash, solder or pogo the pins and read with a programmer. The data cannot be polled externally as the position assignment data is pushed by the receiver and written to specific blocks.
well you could simply send the position number with your reciever and physically check the angle it went to or you could overwrite the prestored positions and configure both tuners accordingly. id probly choose the second option.
crackt out,.
CW Central at 91W Scrambled?
Something simple
