Will a DP receiver work with a standard Ku LNB? I have a Dish 522 dual VDR which is a DishPro receiver. I am going to need to connect it to a larger dish and was wondering what my options were for LNBs. I am going to use a 1 meter or 2 meter Channel Master dish and need to know if I can use a standard LNB with it or if there is a DP LNB that can be used with the CM dishes.
What is the real difference between the DishPro LNB and a legacy LNB anyways? Is the DP LNB doing stacking instead of switching?? I've been browsing all over the web and haven't been able to find information. I see that there is a converter to make a legacy IRD work with a DP LNB, but nothing is stated as to using a DP IRD with a legacy LNB. I also have a DP34 switch that was switching from the dish to my dual inputs on the 522. It was also adding the 61 deg dish in.
The 1 meter dish that was given to me has a Norsat 6607a Ku band LNB on it. It also says lo +/- 500 kHz. This LNB will not work with Dish, let alone a DP IRD will it?
Thanks for all your help. I've been reading, but everything I see is repetitive and nothing addresses my questions.
