DP plus 322 Reciever phone line ???
toptenyears
I have an active DP plus 322 reciever plugged into a phone line in my house that i have been using for about 1 year. I want to move the reciever to a different room and it will be plugged into a different phone line that is a different phone number entirely from the original, is this a problem?
Also, I have 2 UHF remotes that I would like to use to control the same UHF DP Plus 322 receiver. So channel 2 on the receiver could be controlled with 2 different remotes. Ho do I do this????
Phone line won't be a problem. As far as the two UHF remotes contolling TV2 output. Look in your owners manual on how to chage remote addresses and just set the two reomtes that you want to run TV2 output on the same address.
NASCAR in HD?
Just found this sight. (smartcard errors)
