OK, Is this an adequate summary?:
Yellow RCA Video Out, and S-Video are generally not capable of being HD signal conduits. Old technology.
HDMI, Component, DVI, and IEEE 1394 (Firewire) are all viable HD signal conduits. Length of cables vs. wire guage and, in the case of Firewire, balanced pairity are critical factors for adequate performance. So cable choices do matter.
As it pertains to our ViP722, the only HD interconnect options available now are HDMI and Component. Since there is no DVI Out on the 722, it's not applicable. And, although there is a IEEE 1394 (Firewire) port on the back, it is either not enabled as or not even hardwired as an inteconnect to tv for HD signals.
I can distribute 1080 HD to two tvs using HDMI and Comonent outputs.
Or I can split either HDMI or Component to distribute HD at full 1080 to more than two tvs, which requires and active disribution device to amplify/stabilize the signals.
Otherwise, I can distribute HD content in it's downrezzed form along with regular SD through Yellow RCA Video Out, S-Video Out or through the agile modulation coax Home Distribution Ch 21-69 Out.
Did I miss anything?
