Dish Model 942 - L2.27 Software Update
barryb
30
Does anyone know what issues are being addressed in the 942 software release due tomorrow.
Thanks,
Barry
no, one lets you set limits on how many episodes of any one program your unit stores, this way for example your kids have your 942 set to record all episodes of spongebob, your 942 could fill up quick, however with the new software you can tell it you only want the last 5 episodes of spongebob, and the 942 would only keep the most 5 recent episodes.
The second new feature lets you specify the default extended timers, this means at the moment you want to start recirding 4 minutes before a show starts and stop recording 5 minutes after the show is done you would need to set that option each time, now with the new software you can specify a set default so you need not set it every time. :)
I'm hoping it fixes the missing program guide data for local channels problem in many markets. I was told that the next software update would fix this. Fingers crossed it actually does.
Anyone know when we can expect this update to be downloaded? Will it be late tonight? I was hoping that it would be downloaded early this morning, but mine hasn't yet been updated.
I got last report - check your system info screen and the c&p:
Wed Jul 13 07:35:49 2005
Upgrading FW:
'AAA1'- 'APD1' 'L050'- 'L226','NONE'
'AAA1'- 'APD1' 'L050'- 'L226','1110'
'1[01]1A'
'AAA1'- 'APD1' 'L050'- 'L227'
New FW:'L227'
List of BootStraps and BuildConfigs:
'1[01]1[0A]' 'MA[BD-FHJ][A-DJ]'
IRD Model: DP942
List of Serial Numbers:
[117]
68342625 70869816 68342727 69979744 69979767 69996825 68342711 67035184 70167144 69996655
67035191 68342704 70280874 68342659 69996903 68342635 68319414 67035146 68342616 69996836
69996869 67035225 69997041 68342723 68342614 67035115 67035228 68342694 69996651 69996873
68342724 68342778 69996976 68342680 70167053 68342760 69996899 67035107 69996885 67035188
68342710 66980409 68342739 68342693 67035100 68342609 67035154 69996661 68342608 70899302
68342699 67035148 68342715 70745722 67035083 67035186 68342625 68625802 69997037 70167066
69996827 70167066 69979799 70166990 69996816 67035136 68342651 70899586 68342764 69996643
69996732 69915078 68342618 68342641 67035207 69996986 69979677 69996725 67035108 67035196
68342613 68342665 68342615 68002138 67035232 66980412 68002161 68002184 68002179 68342785
68342696 68002178 68342755 68342790 68342642 68342687 68346483 68002165 68002173 68002169
68002174 68002176 68002124 68002180 68002133 68002183 68002141 68002180 68002161 68002192
68002188 68002138 68002131 68002185 67035127 67035142 67035226
DishDave said:
Does that mean you can get rid of the 3min before crap ?
It's one minute before, three minutes AFTER, and I've never understood: what is wrong with that? Especially with name-based recording that expands with the size of the show as detected by the downloaded EPG...
Dish Model 942 - L227 Update
your gonna need to do a check switch after this software download.. i had to for mine.. it couldnt find any sats in the aquireing sat sig screen after download..... witch a check switch fixed.. a noticable fix in this one also is now i have Odd transponders for 61.5 with the evens
Wow is rainbow one weaker than echo 3!!!! Echo 3 im getting all 100's + on rainbow 1 im getting 80's + .... More Tps are avaib from rainbow 1 now but programming is not.. and alot of open tps.. too.
EDIT:
so Im at L227 now..
Still No analog channels allowed in the digital Scan
Still no Games in Dish Home ch 100 for the 942
Added an incactivity standby mode.. This feature powers off the reciver after inactivity duration.. hours inactivity
in the create timer screen it now shows you priority of your timer that your setting like for mine it said 18 of 18, It looks like you can now set maximum events for a timer.. so you stuff wont fill youre hd... other than that it looks all good.. No idea what bugs were fixed this is just a im looing through menus to see what was added...
you can find the maximum recorded events option in the timer options menue.. from there you can change the max record count... it will remove the oldest unprotected events for that timer after a Specifyed amount of events...
additional receiver fee
522 with flakey tuner two
