I know DPP will work with legacy receivers without the DP adapter. Will a DP34 switch work with the Dish 1000 DPP heads?
Correct. There are Int'l services on the 118 such as Chinese, Arabic, South Asian, etc..HD locals for these DMA's....St.Louis, Detroit, Raleigh,NC; Pittsburgh and Charlotte,NCInternationals are on 118, and a few HD locals I believe.
It is a controversial subject. While they do seem to work, they also seem to burn out when used in this config. I am assuming you mean DPP twins. The 1000.2 has a built in switch that is basically a DPP 43 switch. 4 orbitals, 3 outs. The DP34 will not support a seperator as it is not DPP, so a dual tuner would need 2 lines. No legacy support either with DP34s.
You might have answered my question because I did not think of the 4 orbital locations. BTW what programming is on 118?
The reason it has to be like this is the way the house is wired. Every location in has has 2 wires so that is not a problem.
Yer right my fault. I looked that manual today to check my post..???????
The integrated Dish 1000.2 LNB has 3 line outs and a LNB in 4th port that can be used to add a second dish for a 4th orbital. No it will not get the FSS 118 but can get a 4th DBS orbital. In my case I have the 1000.2 looking at 110,119,129, and 61.5. There are only 3 outputs, dual tuner capable so that would be 6 tuners.
This is just like a DPP twin with 3 ports, one LNB in, 2 sat lines out. 1000.2 is the same just 3 lines out, basically a DPP triple.
I didnt understand that the OP was planning to cascade 2 Dp34s off a 1000.2 integrated LNB. The 4th orbital is lost then but as someone said above 5 722's will need 10 lines so 3 Dp34's would be needed.
Lose 129 in winter? Now you have me scratching my head. Ok, I'll bite..How does this happen?..BTW keep the 61.5. better sigsYeah I have a d300 at 61.5. I meant it all goes through the 1000.2 switch and works great so far. Your correct, no single dish solution, should need both 61.5 and 129. I just have 61.5 in case I loose 129 in the winter.
