Check switch installation every morning
The Solo Node on our portable 1K4 and the Duo Node on the 1K4 at our Adirondack cottage have both been exposed to the weather since about 2014 with no problems. For the pictured roof installation, I'd suggest adhering the Node to the roof with a quality double sided tape like 3M's automotive trim tape or similar. Also, the unused port should be terminated.
Thanks, I appreciate your input. I haven't figured out how I'm going to secure it yet. Any input from the RV folks out there would be helpful. I will research and figure out something before we get back on the road.
one word.............velcro
Another option (since TBoyer currently only has two tuners without the Solo Node) would be to simply replace the HWS with a Hopper Duo. A Hopper Duo would work just fine without the Hub, since the Hub is only required if you want to add a Joey.
Hi pattykay. I was wondering if you could ship out a solo node and a 211k to me if you are still available?
OTA channels freeze drop audio
Input button as swap tuner button
