Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 7.5.13.1
Internal Version: 7, 5, 13, 1
(Nero Express)
Recorder: <LITE-ON DVDRW LH-20A1S> Version: 9L08 - HA 1 TA 0 - 7.5.13.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <SAMSUNG DVD-ROM SD-616F >Version: F100 - HA 1 TA 1 - 7.5.13.1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1600AAJS-00B4A0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW LH-20A1S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : SAMSUNG DVD-ROM SD-616F atapi Port 3 ID 0 DMA: On
DiskPeripheral : IOMEGA ZIP 100 atapi Port 3 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1S D: CDRom0
SAMSUNG DVD-ROM SD-616F F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046956kB)
Free physical memory: 665MB (681116kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
29.4.2008
===== Disc-Copy over image - 1st step : Copy to image ...
6:02:54 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:02:55 PM #2 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
6:02:55 PM #3 Phase 48 File dlgbrnst.cpp, Line 1760
Analyzing disc
6:02:55 PM #4 CDCOPY -1 File CDCopy.cpp, Line 1916
The CD is copyrighted
6:02:55 PM #5 Text 0 File CDCopy.cpp, Line 2132
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 17847 17846 ( 3:59.71)
Track 2: 17847 17847 ( 3:59.72) 30762 30761 ( 6:52.11)
Track 3: 30762 30762 ( 6:52.12) 51212 51211 ( 11:24.61)
Track 4: 51212 51212 ( 11:24.62) 66577 66576 ( 14:49.51)
Track 5: 66577 66577 ( 14:49.52) 84575 84574 ( 18:49.49)
Track 6: 84575 84575 ( 18:49.50) 104622 104621 ( 23:16.71)
Track 7: 104622 104622 ( 23:16.72) 119222 119221 ( 26:31.46)
Track 8: 119222 119222 ( 26:31.47) 138730 138729 ( 30:51.54)
Track 9: 138730 138730 ( 30:51.55) 152512 152511 ( 33:55.36)
Track 10: 152512 152512 ( 33:55.37) 166102 166101 ( 36:56.51)
Track 11: 166102 166102 ( 36:56.52) 183717 183716 ( 40:51.41)
Track 12: 183717 183717 ( 40:51.42) 196287 196286 ( 43:39.11)
6:02:55 PM #6 Text 0 File CDCopy.cpp, Line 840
Copy options: copy on-the-fly: ON
read ISRC/MCN: OFF
use jitter correction: OFF
data options
ignore read error: ON write defekt blocks OFF
read raw data: OFF read r-w subchannel data: OFF
audio options
read indexes: OFF read r-w subchannel data: OFF
source disc does not look like CD Extra
01. 0 - 17847 = 17847, audio (TRM_AUDIO_NOPRE, block size 2352)
02. 17847 - 30762 = 12915, audio (TRM_AUDIO_NOPRE, block size 2352)
03. 30762 - 51212 = 20450, audio (TRM_AUDIO_NOPRE, block size 2352)
04. 51212 - 66577 = 15365, audio (TRM_AUDIO_NOPRE, block size 2352)
05. 66577 - 84575 = 17998, audio (TRM_AUDIO_NOPRE, block size 2352)
06. 84575 - 104622 = 20047, audio (TRM_AUDIO_NOPRE, block size 2352)
07. 104622 - 119222 = 14600, audio (TRM_AUDIO_NOPRE, block size 2352)
08. 119222 - 138730 = 19508, audio (TRM_AUDIO_NOPRE, block size 2352)
09. 138730 - 152512 = 13782, audio (TRM_AUDIO_NOPRE, block size 2352)
10. 152512 - 166102 = 13590, audio (TRM_AUDIO_NOPRE, block size 2352)
11. 166102 - 183717 = 17615, audio (TRM_AUDIO_NOPRE, block size 2352)
12. 183717 - 196287 = 12570, audio (TRM_AUDIO_NOPRE, block size 2352)
6:03:03 PM #7 Text 0 File Burncd.cpp, Line 3467
Turn on Disc-At-Once, using CD-R/RW media
6:03:03 PM #8 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 445499 ( 99:01.74)
Last address to be written: 196286 ( 43:39.11)
6:03:03 PM #9 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
6:03:03 PM #10 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
6:03:03 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 792
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (1 - Audio)
2 indices, index0 (150) not provided
original disc pos #0 + 17847 (17847) = #17847/3:57.72
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17847 blocks [Image Recorder]
1: TRM_AUDIO_NOPRE (2 - Audio)
2 indices, index0 (0) provided
original disc pos #17847 + 12915 (12915) = #30762/6:50.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12915 blocks [Image Recorder]
2: TRM_AUDIO_NOPRE (3 - Audio)
original disc pos #30762 + 20450 (20450) = #51212/11:22.62
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20450 blocks [Image Recorder]
3: TRM_AUDIO_NOPRE (4 - Audio)
original disc pos #51212 + 15365 (15365) = #66577/14:47.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15365 blocks [Image Recorder]
4: TRM_AUDIO_NOPRE (5 - Audio)
original disc pos #66577 + 17998 (17998) = #84575/18:47.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17998 blocks [Image Recorder]
5: TRM_AUDIO_NOPRE (6 - Audio)
original disc pos #84575 + 20047 (20047) = #104622/23:14.72
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20047 blocks [Image Recorder]
6: TRM_AUDIO_NOPRE (7 - Audio)
original disc pos #104622 + 14600 (14600) = #119222/26:29.47
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14600 blocks [Image Recorder]
7: TRM_AUDIO_NOPRE (8 - Audio)
original disc pos #119222 + 19508 (19508) = #138730/30:49.55
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19508 blocks [Image Recorder]
8: TRM_AUDIO_NOPRE (9 - Audio)
original disc pos #138730 + 13782 (13782) = #152512/33:53.37
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13782 blocks [Image Recorder]
9: TRM_AUDIO_NOPRE (10 - Audio)
original disc pos #152512 + 13590 (13590) = #166102/36:54.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13590 blocks [Image Recorder]
10: TRM_AUDIO_NOPRE (11 - Audio)
original disc pos #166102 + 17615 (17615) = #183717/40:49.42
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17615 blocks [Image Recorder]
11: TRM_AUDIO_NOPRE (12 - Audio)
original disc pos #183717 + 12570 (12570) = #196287/43:37.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12570 blocks [Image Recorder]
6:03:03 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [Image Recorder] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 12: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 42328944, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 42328944 42328944 72705024, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 72705024 72705024 120803424, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 120803424 120803424 156941904, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 156941904 156941904 199273200, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 199273200 199273200 246423744, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 246423744 246423744 280762944, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 280762944 280762944 326645760, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 326645760 326645760 359061024, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 359061024 359061024 391024704, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 391024704 391024704 432455184, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 432455184 432455184 462019824, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x01 | 17847 | 17697 | 0x00
0 | 1 | 1 | 0x01 | 17847 | 17847 | 0x00
17847 | 2 | 0 | 0x01 | 12915 | 30762 | 0x00
17847 | 2 | 1 | 0x01 | 12915 | 30762 | 0x00
30762 | 3 | 0 | 0x01 | 20450 | 51212 | 0x00
30762 | 3 | 1 | 0x01 | 20450 | 51212 | 0x00
51212 | 4 | 0 | 0x01 | 15365 | 66577 | 0x00
51212 | 4 | 1 | 0x01 | 15365 | 66577 | 0x00
66577 | 5 | 0 | 0x01 | 17998 | 84575 | 0x00
66577 | 5 | 1 | 0x01 | 17998 | 84575 | 0x00
84575 | 6 | 0 | 0x01 | 20047 | 104622 | 0x00
84575 | 6 | 1 | 0x01 | 20047 | 104622 | 0x00
104622 | 7 | 0 | 0x01 | 14600 | 119222 | 0x00
104622 | 7 | 1 | 0x01 | 14600 | 119222 | 0x00
119222 | 8 | 0 | 0x01 | 19508 | 138730 | 0x00
119222 | 8 | 1 | 0x01 | 19508 | 138730 | 0x00
138730 | 9 | 0 | 0x01 | 13782 | 152512 | 0x00
138730 | 9 | 1 | 0x01 | 13782 | 152512 | 0x00
152512 | 10 | 0 | 0x01 | 13590 | 166102 | 0x00
152512 | 10 | 1 | 0x01 | 13590 | 166102 | 0x00
166102 | 11 | 0 | 0x01 | 17615 | 183717 | 0x00
166102 | 11 | 1 | 0x01 | 17615 | 183717 | 0x00
183717 | 12 | 0 | 0x01 | 12570 | 196287 | 0x00
183717 | 12 | 1 | 0x01 | 12570 | 196287 | 0x00
196287 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
6:03:03 PM #13 Phase 120 File dlgbrnst.cpp, Line 1760
Creating the image for burning
6:03:03 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
6:03:03 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #17847): write at #17847
6:03:03 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #30762): write at #30762
6:03:03 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #51212): write at #51212
6:03:03 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #66577): write at #66577
6:03:03 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #84575): write at #84575
6:03:03 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #104622): write at #104622
6:03:03 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #119222): write at #119222
6:03:03 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #138730): write at #138730
6:03:03 PM #23 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #152512): write at #152512
6:03:03 PM #24 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #166102): write at #166102
6:03:03 PM #25 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #183717): write at #183717
6:06:08 PM #26 Text 0 File WriterStatus.cpp, Line 113
<Image Recorder> start writing Lead-Out at LBA 196287 (2FEBFh), length 0 blocks
6:06:08 PM #27 Phase 121 File dlgbrnst.cpp, Line 1760
Creating Image completed successfully
6:06:09 PM #28 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
6:06:13 PM #29 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:06:13 PM #30 Text 0 File Cdrdrv.cpp, Line 10538
DriveLocker: UnLockVolume completed
===== Disc-Copy over image - 2nd step : Burn the image ...
6:06:14 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
6:06:14 PM #2 Text 0 File Burncd.cpp, Line 3156
SMART-BURN activated
6:06:14 PM #3 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 12
1: ISRC = ''
Blocksize = 2352
TrackMode = 'TRM_AUDIO_NOPRE'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 352800, NextTrackFilePos = 42328944
2: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 42328944, Index1FilePos = 42328944, NextTrackFilePos = 72705024
3: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 72705024, Index1FilePos = 72705024, NextTrackFilePos = 120803424
4: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 120803424, Index1FilePos = 120803424, NextTrackFilePos = 156941904
5: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 156941904, Index1FilePos = 156941904, NextTrackFilePos = 199273200
6: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 199273200, Index1FilePos = 199273200, NextTrackFilePos = 246423744
7: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 246423744, Index1FilePos = 246423744, NextTrackFilePos = 280762944
8: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 280762944, Index1FilePos = 280762944, NextTrackFilePos = 326645760
9: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 326645760, Index1FilePos = 326645760, NextTrackFilePos = 359061024
10: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 359061024, Index1FilePos = 359061024, NextTrackFilePos = 391024704
11: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 391024704, Index1FilePos = 391024704, NextTrackFilePos = 432455184
12: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 432455184, Index1FilePos = 432455184, NextTrackFilePos = 462019824
CUES:
0: Ctrl=0x01 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
1: Ctrl=0x00 Trk= 1 (0x01) Index=04 Start=3801:08.52 ( 17105152) RecDep=0x11 [empty/reserved]
MTYP: Mediumtype = CD (old format) (0x1)
Image file name: <C:\Documents and Settings\Hilton\My Documents\TempImage.nrg>
6:06:14 PM #4 Text 0 File Burncd.cpp, Line 3467
6:06:14 PM #5 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 359845 ( 79:59.70)
6:06:14 PM #6 Text 0 File DlgWaitCD.cpp, Line 318
6:06:15 PM #7 Text 0 File DlgWaitCD.cpp, Line 2929
Recorder: LITE-ON DVDRW LH-20A1S;
CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc.
ATIP Data:
Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
6:06:15 PM #8 Text 0 File DlgWaitCD.cpp, Line 490
6:06:15 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 792
2 indices, index0 (150) provided
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17847 blocks [D: LITE-ON DVDRW LH-20A1S]
2 indices, index0 (0) not provided
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12915 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20450 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15365 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17998 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20047 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14600 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19508 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13782 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13590 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17615 blocks [D: LITE-ON DVDRW LH-20A1S]
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12570 blocks [D: LITE-ON DVDRW LH-20A1S]
6:06:15 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: LITE-ON DVDRW LH-20A1S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
DAO layout:
-150 | 1 | 0 | 0x01 | 17847 | -150 | 0x00
0 | 1 | 1 | 0x01 | 17847 | 0 | 0x00
17847 | 2 | 0 | 0x01 | 12915 | 17847 | 0x00
17847 | 2 | 1 | 0x01 | 12915 | 17847 | 0x00
30762 | 3 | 0 | 0x01 | 20450 | 30762 | 0x00
30762 | 3 | 1 | 0x01 | 20450 | 30762 | 0x00
51212 | 4 | 0 | 0x01 | 15365 | 51212 | 0x00
51212 | 4 | 1 | 0x01 | 15365 | 51212 | 0x00
66577 | 5 | 0 | 0x01 | 17998 | 66577 | 0x00
66577 | 5 | 1 | 0x01 | 17998 | 66577 | 0x00
84575 | 6 | 0 | 0x01 | 20047 | 84575 | 0x00
84575 | 6 | 1 | 0x01 | 20047 | 84575 | 0x00
104622 | 7 | 0 | 0x01 | 14600 | 104622 | 0x00
104622 | 7 | 1 | 0x01 | 14600 | 104622 | 0x00
119222 | 8 | 0 | 0x01 | 19508 | 119222 | 0x00
119222 | 8 | 1 | 0x01 | 19508 | 119222 | 0x00
138730 | 9 | 0 | 0x01 | 13782 | 138730 | 0x00
138730 | 9 | 1 | 0x01 | 13782 | 138730 | 0x00
152512 | 10 | 0 | 0x01 | 13590 | 152512 | 0x00
152512 | 10 | 1 | 0x01 | 13590 | 152512 | 0x00
166102 | 11 | 0 | 0x01 | 17615 | 166102 | 0x00
166102 | 11 | 1 | 0x01 | 17615 | 166102 | 0x00
183717 | 12 | 0 | 0x01 | 12570 | 183717 | 0x00
183717 | 12 | 1 | 0x01 | 12570 | 183717 | 0x00
6:06:15 PM #11 Text 0 File SCSIPTICommands.cpp, Line 209
6:06:15 PM #12 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 24x (3,600 KB/s)
6:06:15 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 0 (relocatable, no disc pos, patch infos, orig at #0): write at #0
6:06:15 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 1 (relocatable, no disc pos, patch infos, orig at #17847): write at #17847
6:06:15 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 2 (relocatable, no disc pos, patch infos, orig at #30762): write at #30762
6:06:15 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 3 (relocatable, no disc pos, patch infos, orig at #51212): write at #51212
6:06:15 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 4 (relocatable, no disc pos, patch infos, orig at #66577): write at #66577
6:06:15 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 5 (relocatable, no disc pos, patch infos, orig at #84575): write at #84575
6:06:15 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 6 (relocatable, no disc pos, patch infos, orig at #104622): write at #104622
6:06:15 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 7 (relocatable, no disc pos, patch infos, orig at #119222): write at #119222
6:06:15 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 8 (relocatable, no disc pos, patch infos, orig at #138730): write at #138730
6:06:15 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 9 (relocatable, no disc pos, patch infos, orig at #152512): write at #152512
6:06:15 PM #23 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 10 (relocatable, no disc pos, patch infos, orig at #166102): write at #166102
6:06:15 PM #24 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 11 (relocatable, no disc pos, patch infos, orig at #183717): write at #183717
6:06:15 PM #25 Text 0 File MMC.cpp, Line 17597
StartDAO : CD-Text - On
6:06:15 PM #26 Text 0 File MMC.cpp, Line 22275
Set BUFE: SMART-BURN -> ON , SMART-BURN : ON
6:06:15 PM #27 Text 0 File MMC.cpp, Line 17827
CueData, Len=120
01 00 00 41 00 00 00 00
01 01 00 00 00 00 00 00
01 01 01 00 00 00 02 00
01 02 01 00 00 03 3b 48
01 03 01 00 00 06 34 0c
01 04 01 00 00 0b 18 3e
01 05 01 00 00 0e 31 34
01 06 01 00 00 12 31 32
01 07 01 00 00 17 10 48
01 08 01 00 00 1a 1f 2f
01 09 01 00 00 1e 33 37
01 0a 01 00 00 21 37 25
01 0b 01 00 00 24 38 34
01 0c 01 00 00 28 33 2a
01 aa 01 01 00 2b 27 0c
6:10:58 PM #28 SPTI -1033 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x2A 00 00 02 1D DC 00 00 0E 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
Buffer x07420900: Len x80a0
0xFF FF 00 00 FF FF FD FF 01 00 02 00 FC FF FD FF
0x03 00 02 00 FC FF FE FF 02 00 00 00 FF FF 00 00
0xFF FF FF FF 02 00 00 00 FC FF 00 00 03 00 FF FF
6:10:58 PM #29 CDR -1033 File Writer.cpp, Line 299
Drive not ready
6:10:58 PM #30 SPTI -1033 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
6:11:04 PM #31 Phase 38 File dlgbrnst.cpp, Line 1760
Burn process failed at 24x (3,600 KB/s)
6:11:04 PM #32 Text 0 File SCSIPTICommands.cpp, Line 254
6:11:07 PM #33 Text 0 File Cdrdrv.cpp, Line 10538
6:11:07 PM #34 Text 0 File SCSIPTICommands.cpp, Line 411
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 11/3/2005 3:00:00 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 11/3/2005 3:00:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
