Hi, i have found the T5 but one thing i can't get it with a stronger signal 77% percent of Q that is what i have and some other frequencies are low 66% percent because of that , and my S is 86% what do i need to do . ( it's to low in case of rain am i correct )
On that same direction i got 99% percent of Q, but it's only when i don't tight and straight the skew also no name shown i end up scanned it with that 99%, but nothing came up please help
You can tweak the skew some until you maximize quality. I'm near San Jose California and I get signal of 91% and quality of 79% on this transponder. I'm using a 36" dish, an Invacom Quad LNB, and a Coolsat 7000. So I would say 77% quality is pretty comparable to my results, though it depends a good bit on the signal meter in your receiver. I actually get better than 85% quality on many of the transponders. For example, just checked 11716/V/22000 which I thought was weak from looking at the list, but I'm getting 90/87 right now.that was exactly the transponder i scanned it 2 12152, should i keep the skew straight or lean on side or play with it slowly until i get stronger Q signal, and i believe with 77% percent of Q mean when it's rain the signal will go to low and will end up to lose signal am i wrong, and some channel the quality are clear but some don't,
Do anybody knows any thing about Nimiq 1.93 west
Cause I heard it moved to Hd is that clear cause my brother said it's down
yes, if you don't have something blocking the signalwould i be able to catch it from where i live
