Can I convert by C Band dish by replacing the LNFB with a KU band LNFB and putting tin foil over the dish?
My 6 footer is about as worthless as Dish network.
> Be sure to use a PF Ku LNBF.
I thought all LNFB's where the same as in you mount them where it will get max signal. I did not realize there was a Prime Focus LNBF and an Offset LNBF?
That prime focus LNB ROCKS on the 6 footer. I tried it a while back on one of my 6 footers and most sats it maxes the meter....Eden Satmex5 which is a bugger in MN to get I got stuff in the 70's quality wise...on the 36" 0-10
I think the last line in my signature says it all
An interesting experiment Ice would be to toss a Direct LNBF on the Fortec 6 footer and see how it fairs in a wicked storm...
ikki said:Thank you for shopping with -Satellite AV, LLC!
Your order has been processed...
LNBF - SL1P - GEOSATpro SINGLE STANDARD KU PRIME FOCUS
That prime focus LNB ROCKS on the 6 footer....
