Best Set-up?
You enter the correct LNB info?
Also, many people do not know exactly where to be looking when setting the angles. Seems many people just assume that the bolt are the indicators, and on some units, they are not.
I can not take good pictures to show anything. I do go by the meat of the plate for elevation adjustment. bolt>washer>meat> align to the edge of the metal.
I put an inclimeter on the dish, the LBN side, in the area of the mounting bolts of the dish to measure it's degrees
You are correct using the meat of the dish, some where reading from the center of the bolt. Can you tell me this becuase I haven't seen a photo showing the area of the metal edge. Is there red paint on the edge of the plate drawing your attention to this area?
No red paint. It was all painted white. I feel it was not right so I used my inclometer (the one used in the set-up drawing on Sadiom set-up web-page) and got myself in the 23-24 degree area.
I have my motor set at 41 on the latitude side (not the alititude side) so I should have found something. I hope krisman gets the message I sent.
He sent me an email yeterday stating he finally got his system aligned. So maybe he knows something we don't.
Most dishes add a little red paint drawing your attention to this area, makes it a lot easier to figure out where to take the dish elevation reading from. Using the inclinometer was a good idea to confirm this for you.
That transponder on nimig comes in strong for me near Omaha NE location. And you should be able to use that circular broadcast to find something on the arc. Just one question to ask, is there a tree or building that might be obstructing this signal?
Photo doesn't display but will take your word. If your in SE Iowa, 91W is high on the arc so very few things will obstruct the signal.
Your mast is perfectly plumb? Checked all directions with a level?
Something else is wrong. Nimiq is a very easy Sat to hit, a couple of Degrees off won't keep you from getting some type of Quality.
I'd re-set the Dish and Motor using the scales on the items. Double check the pole for plumb.
Start East of you target and twist the Motor / Dish on the pole to the West.
Use a compass to confirm you have covered enough area.
To even simplify things, bypass the Motor and switch, just connect the In-Line Meter.
Just right click the link and open in a 'New Tab' or "New Window'.
Plus i just looked at:
Fortec Star Dish Elevation Calculator
And entered in for 91.72 W and 40.76 N gets for a fixed:
42.6,,,, 188.1,,,,,6.1 Skew
for H120 motor 41.6 Dish elevation
for hh100/hh120: 26.6 Dish elevation
And for my motect SG2100 states 23.6,,,,,, but I see a offset on my dish of 24.62
I am done. I am going to give up until it quits being windy. I lost my paitience with this system, and the wind has got me madder than a junk yard dog!
I tried elevation up and down, east and west. And can not find anything. I thought I would get something.
My inclometer states at 23-24 degrees for dish, and motect is at 41 degrees, and the recieve was scanning and get no darn Quality. It is sickening to fight with this by myself. Gpoing out and move just a 1/32 to 1/16 inch and come inside and not get anything. Plus this wind shaking the dish all over the place, even with the mast plumb, but it shakes in the wind too. So I will have to stiff'en the mast up.
My dish elevation is at about 30 degrees but my inclimeter says the dish is at 23-24. So which is true. I put the inclimeter in the rectangular section on the LBN side, and that states the 23-24 degree.
I can not bring the dish down any. It will hit my little storage shed when in movement. Unless I set my stops on the motor. I will not know how far my horizens will be if I do that.
I might have to go get a little moniter, and bring the reciever out to the dish site. It might be cheaper that a birddog sat meter.
I would swear you said you were doing that already, but re-read the posts and you did not.
YES, if at all possible bring a TV & Receiver to the Dish.
Also, if you have an old 18" DBS dish handy you can use it with the meter & receiver to find nimiq 1. This will tell you exactly where it is without any motor, switch, or lnb variables. Then you can mark the pole and that will be 0.7° from your starting point for the motor.
Hello, I did get Nimiq 1.3 yesterday Late thou.
I went in an set Nimiq 1.3
Moter:
>Three choices:
>>Disable
>>Moter
>>USUALS
I selected 'USUALS'
Satellite: Nimiq 1.3 (91.0 W) [this is what is on the screen]
Latitude: 40.8 N [I inputed]
Longitude: 91.7 W [I inputed] In the USUALS, I had inputed my location.
Step Size: Continuous [or incrimints of 1, 1-5] (I am going to have a question on this, so read on.)
Move: Stop [it is stoped] (but has 'drive east' and 'drive west')
Limit: OK (when Highlighted) [has three choices: Limits: off, east, and west]
Now below this is My remote function keys:
Red Key: "Store Position
Green Key: "Go To reference"
Yellow Key: "Exit"
Blue Key: "Go to Sat Position.
Ok, here is my question (s):
I started with my "pole set for 'True South' " Marked with incrimints on pole to find this satellite. So my Motect SG2100 is set to "0". Finally got a:
S: 65-67
Q: 62-63
(It was late and did not get any fine tune done.)
So now I know where to point at.
Today I want to absolute fine tune. So the question is:
Do I:
"Red Key" store postion? And fine tune more from this 'Stored location'?
"Green Key" "Go to Reference"
>What does that mean?
If it means Satellite Location imputed by software, to go to that Satelite postion from "My imputed location".
So that will give me a click or two (east) on the Motect SG2100 and will move my LNB to a required 'Skew"?
Blue Key "Go to Sat Position" another un-answered question from my manual. So is this my reference Position, or again is it another position?
Which ever one, I want my mast-to-motor to be at my 'True South'. Drive the motor to Nimiq 1.3 and get the very best reception possible (In it's true pointing direction, to hopefully get the arc!)
So once I got that set-up to get this signal strength, I went and tried to get the other satellite in the same location. (According to the firm ware loaded, I should have Galaxy 11 (C) @ 91.0 degrees, and Galaxy 11 @ 91.0 degree) But nothing there.
Galaxy 11 (C) i get S: to port 1 (L), and port 4 (C)
Port (linar=L=1) LNB FREQ 5150 (S:65), and 5750 (S:44) but no Q: for both.
I click on each transponder, and it moves the S: but get no Q:!
So I went to Motor> USUALS> 'Blue Keyed" Go To Sat Postion.
Tried some transponders. Nothing
Went ack to Moter> USUALS> Green Keyed (Go to reference) and now I get no S: to transponder. It acts like it is not getting power out to the transponder. I might have to check all my connections, and might have to replace them. I even went back to the Nimiq 1.3 and no S:
So I moved my antenna and now I am getting a satellite named:
Anik F3 [72.0 W) Then went and look for it in the list not there. So I scanned the sat, and came back to Nimiq 1.3 I do not know
Robert_W,
Let me answer the Galaxy 11 (C) question for you first. This is a C-band transmition you are refereing to with frequency around 5.000 ghz. At orbital position 91W you have a Cband broadcast, a KU linear broadcast and KU circular broadcast. One other note to make the new satellite at that location is now Galaxy 17 and replaced 11.
So look at your list of sats for 91W, do not pick any with (C), that stands for C-band. There should be another KU sat listed at that orbital location. The Invacom QPH-031 will not get any frequency below 11.700 gHZ. Check lyngsat.com for the channels, and transponder information for Galaxy 17 at 91W orbital position.
OK now on to the next questions. What you are supposed to do is set up the dish on the pole and have evrything referenced to zero on the motor. Then input your longitude and latitude in motor control and select USALs, then blue key I think or which ever is called drive to sat. Then the store position key. Then go out to your pole and turn the motor on the pole by hand to align with 91W. That is how it is supose to work in that order. If you did it this way even if 91 was 5 degrees off of your true south, you would still be aligned to the top of the arc. I would have to read over your post again, but think you may have done something out of order.
It does not matter even if you were pointed NORTH to begin with, once you enter your latitude and longitude and select a satellite position using USALs, the motor will rotate the motor tube to the correct orietation of the motor scale. It is up to you at this point to then manually postion the motor on the pole for correct azimuth, and tweak in the dish elevation as well.
Now one note to make and then I will explain some problems you might encounter. When you select go to reference, that is supose to drive the motor back to 0 on the motor scale.
Here is the problem with the Sonicview 360 Premeier that I have encountered; sometimes you select go to satellite, and it goes to reference. Sometimes you select go to reference and it will go to the satellite, sometimes it works but not for all sats selcted. Some times you store the sat position and it works, sometimes selecting store position erases other satellites, sometimes when you go to scan it will drive to a different satellite and scan that, sometimes it has a mind of its own and you never know what the hell this receiver will do next, sometimes it will stop scanning and delete all channels. I could go on forever with weird stuff this receiver does. AND THIS BE MY POINT HOW DO YOU TRUST THIS RECEVEIR TO ALIGN TO THE ARC IF USALs IS SO WEIRD!!!!!
By the way, if you select continuse and start move, the only way to stop is select stop. The incrimental move but (do not quote me) I believe for 1 = 1/10 degree 2 = 2/10 and so on and so forth.
Krisman was fighting USALs for sometime on this receiever, but he told me he got his system to work. Did he ever PM you with what he found to get it to work for him?
Thanks all the replies, For my and Krisman's post too. We have the same system, and there was alot of reading between the two to get my system up, where he is two days ahead of me.
What I did was get mast up, and with the web-site of 'Dishpointer.com' it gave me a line-of-sight. So I was able to have an idea of which way to point, after getting my Motor as close as I could to the south side of pole.
Then I got to my Satellite as close as possible to my 'True South' and thanks to a few of you I knew which transponder to be set at and the frequency to capture that satellite.
I entered under the "Motor" Menu, I put in my location. Then after that, on this Sonicview 360 Premier, I pressed the 'Blue Hot Button" (on the remote controll) to have the motor drive to what the sonicview's program assigned from my location ((((I have learn it is not a 'true' USUALS verified product)
Once I got the hightest signal, with that satellite, with my reciever's USUALS, I had my "TRUE SOUTH" and I did get to Galaxy 18 @ 123 degrees and now have some programs on that Satellite.
I am starting another post to help understanding "Frequencies, Transponders" and how-to-read the Lyngsat.com
Are you also looking at "The List!" at the top of this forum? And ftalist.com has good information about free channels. Easier than wading through LyngSat sometimes.
Thank You Gilham,
Yes I have gone to those sites and could not understand tham that well. But I tell you what,,,,
THE LIST is great here on Satellite Guys. And people are great here. Thanks to all of you.
Thanks to Walrus too. About the understanding of "THE LIST"! Which will help us N:):)-bies, get a better understanding.
I am enjoying the ARC now! I can tweek a little bit but I am getting quality, so why mess with it!!!
I got 123 degree (Galaxy 10R), just got the 99 degree (Galaxy 4R).
Now I will have to see my partner Krisman has got in his post about the "NBC" "CBS" and any Avalialbe movies that might be able to watch.
Any suggestions?
Thanks,
Robert
If you're looking for a new challenge, try to lock RTN on 83°W! <insert evil laugh>
More seriously though, RTN is a great channel for old TV shows and such. It is often tough to lock due to low power.
White Springs TV @ 129°W has old movies. Other than that there are a number of International channels on 97°W that show movies. Usually in a foreign language, but I've see a few people post that some channels run the occasional English movie with sub-titles.
Anyway, congrats on getting that setup and fire away with the new questions!
LNB Question(s)
Iceberg seen this?
