Bad Separator?
imgmkr
8
I have a 622 receiver running off of a two D500's with a DPP twin and a DP dual. The system has been working perfectly for 2+ years. Problem is all of a sudden I'm getting no 110 or 119, only 61.5 on input 1 but I'm getting all 3 just fine on input 2. However, It seems that I am only able to watch 61.5 on both tvs. When I switch the wires from the separator and run a check switch, nothing changes. Is this a bad separator or bad wiring, a bad receiver, or bad LNB?
its the reciever.
HOWEVER
did you try unplugging the receiver for a minute, plugging it back in and re-running the checkswitch?
sometimes this fixes an issue like yours.
also, check the outlet. bad wiring can cause this as well.
722K auto update prob?
Split my signal
