Hi Guys,
Is it possible that one of my LNBF (specifically 118) is bad if I get bad reception on couple of channels from that satellite (on a few transponders only)? By bad reception I mean, vertical lines visible on the screen especially on 1 channel. This channel also has waves going from bottom to top. On another channel the vertical lines are pretty obscured and only visible in certain cases. Yet, all other channels from that sat I am getting seem ok. So, is this LNBF is bad or just those channels are being transmitted in that way or broadcast problem?
My initial thought was that if LNBF was bad, then ALL of my channels on that SAT would display similar problems from all the transponders on that sat. But, I do not know as much as you do. Maybe it is bad LNBF.
Thank you
Thank you
