Thanks. I'll hook it back up and give it a try when I get a few minutes. I've backed up in the past but never had this problem.Hello Joe, On the A3, one thing I have learnt to do during backup, is to do it in stages. I first back up the system files. When done, I backup all apps except the ones that are very large, like Kodi, as such apps may take a long time. I have had many instances of the backup failing when I try to do it all in one go. Also, each time I select a single system file or app, I check that the corresponding size shows up adding to the total. this is to verify that the file was selected and loaded properly. The process has always worked for me and may prove of help with your A3 recovery.
NAND recovery completed! I'm hesitant to upgrade to ver78. Let's see how long it will last this time.The A3 "Stuck in Boot" Gremlin is back again!!! I just did a NAND recovery just a couple of months ago on this thing!
What version are you currently using?NAND recovery completed! I'm hesitant to upgrade to ver78. Let's see how long it will last this time.
I'm staying with Ver.72 for now.What version are you currently using?
Had a real head-scratcher today. The A3 got stuck on boot, as usual. Pulled the plug, let it sit for a while, and on powering up it came up to the initial install screen, as is usual lately. Then I went to the backup utility to restore my settings, only to be greeted with a "No Space" message! I tried deselecting apps so the only thing to restore was the system settings, and still "No Space". Rebooted it again (surprisingly, it started on the first try this time) and it came up with everything normal, as if it had never crashed at all! Nothing needed to be reloaded, all my apps, channels, and settings were there!
What. The. Hell.
There's some very weird stuff going on with Android on this box!
I checked only one item on the list to backup. A3 went immediately back to the previous Backup/Restore screen, same as before. Tried with another backup file. Ditto. Tried another backup file. Same result. Also tried checking several items on the list. This is what started the whole mess to begin with. Don't know where to go from here. Right now the A3 is a boat anchor. Sad. I really liked the A3.Hello Joe, On the A3, one thing I have learnt to do during backup, is to do it in stages. I first back up the system files. When done, I backup all apps except the ones that are very large, like Kodi, as such apps may take a long time. I have had many instances of the backup failing when I try to do it all in one go. Also, each time I select a single system file or app, I check that the corresponding size shows up adding to the total. this is to verify that the file was selected and loaded properly. The process has always worked for me and may prove of help with your A3 recovery.
Less than 2 months after the last Recovery, the A3 is back at it again. It seems to me it does matter what Version is installed the issue will still arise. I'm upgrading to Ver.78 This is really sad!!NAND recovery completed! I'm hesitant to upgrade to ver78. Let's see how long it will last this time.
Meant to write it "doesn't" matter what version is installed.Less than 2 months after the last Recovery, the A3 is back at it again. It seems to me it does matter what Version is installed the issue will still arise. I'm upgrading to Ver.78 This is really sad!!
I was using .78 when it first happened many months ago.I have had no different issues with .78.
