So here is the story:
About two weeks ago my 722K started freezing up once every two to three days..
By this I mean that:
When switching channels, the info banner would stay on the old channel, the picture would switch, and the sound would not follow a pattern (sometimes switch and sometimes not).
At this point, the remote would stop functioning and a reset was required.
Occasionally, even this did not work and it would take 4 or 5 tries to get it back.
When it took more than one try, it would start up like it should but as soon as the channel was changed it would lock again.
I checked my temps and everything looked good except for the max (90/118/138).
Just in case, I removed the doors to my cabinet but the problem continued.
Stumped, I actually started tracking the problem and found that it only happened when switching away from a OTA channel.
After pulling the OTA module, I have not had any issues for three days now.
Based on this my assumption is that the OTA module is failing which brings up a few questions:
1. Since I purchased this separately from DISH is it covered by the service plan?
2. Is this a known issue that will repeat with a new module.
3. Would the Ebay Dual Fan unit help with this or is it temperature independent.
I am planning on waiting till the end of the week to confirm it is the OTA module before contacting Dish so I am just trying to collect information for now.
Thanks,
Thanks,
