As mentioned in a prior thread, I'm firing a DSR 922 back up & getting ready to try a FTA system. In the process it was recommended on the forums here that I get a C1-PLL LNBF for ease of use (takes care of the polarization/skew), as opposed to my current setup with a Chaparral Corotor II Feedhorn & Norsat LNB. I hope there are some 4DTV users left out there!
First I should note this is *not* a comment on the LNBF itself, as I'm just barely testing things out and have yet to tweak anything...and some things are slightly, although carefully, gerry-rigged.
Short story version: after having peaked the dish with the Chaparral last weekend, I swapped out the Chaparral for the C1-PLL today, and no signal. That was the scary part, but Titanium was very helpful in telling me which setting I needed to change on the 4DTV (besides the LNB type) - Rotate 90 degrees. That solved the "0" signal issue.
Early into the upgrade, I am getting lower signals on the new LNBF than I was with the Chaparral...75 vs. 99 on DCII channels. Even if I put the Chaparral back, which I did, and without a lot of accuracy, the DCII signal levels jump back up to the 90's. I swapped again for the C1-PLL and still received the same signal as before, from the same satellite - 70's. I've been using AMC 18 to test from, the HITS channels. Even after some adjusting for focal length, the signal did not improve.
Ultimately, I will not be using the 4DTV as a tuner...I am getting an Amiko Mini HD SE, so I don't even know if this receiver is the right one to be checking signals on with this type of LNBF - but - I did want to ask: is there anyone who has had experience using their 4DTV with this LNBF to pick up Digicipher II signals, and what has your performance been like?
I'll be meeting up with our local tech next week to fine tune all of this, using the Amiko once I have it. Again it is probably a matter of some much needed fine tuning on an old dish, but would be interested in any feedback from 4DTV users out there...just to put my mind at ease that everything I've got and am getting is compatible. Thanks!
