Hopper 3 remote batteries
Twice over seven months is not abnormal. Depends on the amount of usage.
Yeah, if you use skip forward, or back, a lot you are draining battery with each press of the button. If you are only pressing the on button and changing a channel from time to time, not so much.
I get atleast 8 months if not closer to a year on batteries. But I've found over the years not all remotes are created equally. Some do actually drain faster for some reason. And I've also found that remotes that don't get used often die even quicker. I'd go to a house I installed at two months ago and there will be a bedroom that's been used once or twice and remote is already as dead as it gets.
I put these two 50.0 remotes into service a little over 4 years ago and they still have the original batteries.
Silly question: are your batteries actually dying (it won't register button presses), or are you just getting the popup warning on the screen?
The reason I ask is that I have gotten SW updates that cause the warning to pop up even if my batteries have plenty of life left. Then in a subsequent SW release it goes away. Sometimes it comes back later and the cycle repeats. This happens on both my H3 and my Joey 4's .....
For my main H+, I perform a daily morning remote control roll call in the diagnostics menu looking for low batteries. This Hopper has eight remotes paired to it. Sometimes I use my battery tester to double check a remote batteries that indicate low voltage and they are infact low.
  • Wow
Reactions: tjboston5676
I use rechargable NiMH batteries, and mines lasts for 1 year and I press the skip and back buttons like 50 times a day. What I noticed is not all batteries are drained at the same time as one of the two will drain first before the other will.
I purchase big package batteries at Sam's Club.
As per the article's finding, I've been buying AC Delco. I can't say they are the best, or better than, but with my Harmony remotes and under counter kitchen lights last longer than Amazon Basics by a long shot!!!
Joey 4's Lose Streaming & MOCA Internet, but Dish programming works fine
Channel Guide Issue
