Here's today's final update on this EHD situation. With the 4-port USB hub I tried connecting all 4 EHDs at once (to recap, that's 6TB, 4TB, 2TB, and 1TB) and it wasn't clear why after rebooting that the only drive visible was the 2TB drive. I shut down the 2TB drive and none of the other drives became visible until I disabled the USB connection and reconnected it, but then it required me shutting down all of the drives before it would see that single drive appear.
So, in conclusion, I could connect my 6TB drive and add the 1TB drive. Or, I could connect the 4TB EHD at the same time as the 2TB drive, the 4TB with the 1TB drive, but not the 4TB, 2TB, and 1TB drives all at once.
Finally, when I rebooted with the 6TB EHD connected with the 1TB drive, the smaller drive showed up as EHD 1 and the 6TB drive as EHD 2. I think that is due to the large number of events present on my 6TB drive which takes a few minutes to index after rebooting. The 1TB drive had one event that I was using for the tests.
Could it be that each drive is slightly over the drive size, like a 1TB is really 1.068TB. That would make the sum more than 7TB.
Earlier in this thread I had documented the reported available sizes for the different EHDs I have. The 1TB drive reported 930MB in the Hopper GUI and the 6TB was 5,585GB; from memory the 2TB was 1,810-ish GBytes and the 4TB EHD was around 3,600-ish GBytes.
