My bad, typo, it's on 17.4 out of Philadelphia.Here's one that'll get a "Huh?" out of you, channel 29.4 (FOX Phila) is the "Mummers" channel and basically replays the New Year's Mummers parade every day.![]()
1) there is currently no financial incentive to add commercial inventory to this market.
While I give them that, 1 SD subchannel doesnt make THAT much impact. And just because you have the "full" signal you dont have to use it. Hell my local FOx has no subchannels (they're just cheap) and they dont even use the full bandwidth2) we choose to provide the highest possible quality HD broadcast and adding sub channels does have an impact on quality of signal.
sure it does for cable. You can ask for the subchannels to be carried. Every subchannel in Minneapolis on a full power station with the exception of Grit & Justice (both new as of January) is carried on Comcast in Minneapolis. That is 11 subchannels carried.3) our redistribution agreements (cable and satellite) do not provide for additional channel distribution, so any subchannel would be limited to over the air viewers only."![]()
Maybe it's just me but I would rather have more than one choice of channels to watch and have a some degradation in quality than have one channel with perfect quality that is airing something that I am not interested in.
no.Here's a question, if the primary was 720 instead of 1080 would there necessarily be any noticeable degradation by adding just one sub?
What is Mobile TV?Be happy you arent in a "major" market that some stations have decided to use their bandwidth for Mobile TV.
https://en.wikipedia.org/wiki/Mobile_television#Digital_TVWhat is Mobile TV?
seems odd as ABC has Live Well in HD and SD and NBC is using mobile there tooWell that appears to explain why FOX 29 out of Phila has the worst signal of the 4 major OTA networks.
I've never seen a device that had this capability, or advertised that it did.https://en.wikipedia.org/wiki/Mobile_television#Digital_TV
and the areas where it is being done and what stations
http://rabbitears.info/market.php?request=atscmh
Both Fox & NBC use 1.83MBps for mobile (per rabbitears)
Look at Minneapolis ABC (KSTP)... 7.34 Mbps !!!
what do you mean?FOX 29 is also replicating on 38.1 and 38.2, whatever that may mean.
ok NOW it makes sense. Rabbitears doesnt list the Allentown translator as active and the FCC still shows it in Construction Permit stateFOX 29.1 and 29.2 (Movies!) are replicated on 38.3 and 38.4 (Movies!), (I would have corrected the original post but there's no ability to edit). I have them all scanned in on 4 different tuners. 38 (WTXF-TV) is a translator out of Allentown PA. It went live on December 29th, 2014.
