Can anyone tell me how to know how hot my 722 is running. Have had 2 messages that it is too hot so have moved it and added a fan but would like to know more about this?
Man this is like a bad joke, no one has said how to toggle the volume limiter on and off. I have looked in the menu and I cannot find it. I am sure its there, but I can't find it. Anyone?
There is a thread on volume leveling. It's menu 6-7 then disable under the volume leveling.I been griping about how bad it sounds from 10 mins after I got it. :rant:
Well I know i have the new software since I now have the ads in my guide, but I do not have any option under "Dolby Digital" in the Menu for volume leveling. Just asks me to select a external decoder and line or RF mode.
whattchel1
Is NOT ONLY 722K having this audio drops problem, is on all my receivers. I have 722K & 2 722's & 612 all the same! And I watching the show on 722 having the same problem!
My 722K was working fine until L661. Now it acts as though possessed. It is connected through an HDMI cable. There is now no sound unless I turn the receiver on before I turn on the TV. Then sound randomly disappears from random mapped-down (below 100)stations, but stays ok on the upper companion station in the 6300 range. Some random stations produce only an error message until I hit the magical red reset button. The skip forward or back buttons jump anywhere from five second to nearly five minutes a pop. I emailed customer support three days go and have received no response. I've done every troubleshooting trick in the book, including replacing the cable and then some. It is quickly becoming a royal pain in the neck.
Digi, I guess when you say all receivers you mean the 722's since they are getting L661 even though I hope you mean 622's when you say all receivers.FYI on L661 - full release to all receivers starts Thursday
Volume leveling support, EPG Banner Ads, WA 1K.4, Fix PPP (Phone) with IP Connected (CSA), IPTV Play Buffer from 10% to 5%, Remove Phone Line Nags, DRA Sat. Timer fixes, EBR default timer updates, MPEG4 Trigger fixes, QPSK-T legacy Checkswitch fix, possible 004 fix, full VOD in EPG @ ch. 1 support, Misc.
Well phooey! They are trying my patience. Thanks Digi!I am talking about 722k when I saw all.
I have had two programs this week exhibit the 'skip to end' bug.
This is where it shows the entire program recorded, but at some point in it, it skips to playback over. There is no way around it. Tonight it happened on 'Lost', so now I have to wait for Hulu to put it up and hope no one tells me what happened.
I have also had two reboots today.
I hope this one doesn't get problematic.
622 will get it too!
