I decided to switch receivers from a MicroHD to an X2 Premium. Before I ask my question, here is a diagram of my current
setup:
X2 > VBOX > USALS HH-Motor (Ku dish) > MODIFIED WNC Switch > C-Band Orthomode Feed and KU-Band Dual Output LNBF
The X2 Drives the BUD without problems. However when I switch to a Ku Sat (HH-Motor USALS), the X2 drives the BUD
and not the HH-Motor motor. It makes no sense at all but the X2 drives the VBOX to position 23 when it should be driving the
HH-motor. It doesn't make any attempt at all to drive the HH-motor. The only way I can move the HH-motor is to go into MENU>
ANTENNA SETTTING>USALS>PRESS "GO" button. Then it will move the HH-MOTOR to position. If I'm viewing a Ku Sat then
switch to a C-BAND Sat, it works correctly (drives BUD to desired position). The only way I know how to resolve this would be to
install a switch before the VBOX. Then we're back to the "don't drive a motor through a switch" problem.
Any suggestions you might have would be appreciated!
setup:
