Working on the System
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,271
27,970
Newington, CT
I am currently working on the system, you might notice some issues with the navigation bar and the arcade.
I am working to restore them both.
?Thanks for your patience. :D
Me too...
A software upgrade screwed it up as it didn't like an older plugin... so I removed that older plugin and that broke things worse...
?I will fix it though. :D
BTW for those of you who need / want the navigation bar you can temporarly use the vBulletin Default Skin which you can access by CLICKING HERE.
Once things are fixed your look with default back to the main look. (If you were using a different style you can then switch to that one again.)
Making good progress. :)
While I am doing this I am trying to phase out the old plugin that use to make the navigation bar and instead use the one built into the vBulletin software. The old Plugin was causing issues.
?So with that I am still working. :)
Ok the navigation bar is all fixed. :)
However the Arcade is dead... it has been causing all kinds of database issues and with the php upgrade it no longer works... unfortunately the Arcade is no longer supported by the author so I had no choice but to remove it. :(
Almost fixed. This is what SatelliteGuys Black looks like, and when I click on one of the dropdowns:
Oh, and the bar does not show up on the Subscriptions page.
Here's what it looks like on the Dish forum page...the dropdowns are scrunched into the text above.
Ok, it is on the Subscriptions page, but buried/hidden until I hover over it. I'm using Chrome 30.0.1599.69 on Windows 7:
Yeah it was fine 10 mins ago, now it is all a mess.
What kind of issues are you seeing now? As I wasn't touching anything for about the last hour... may have been something stuck in the cache...
How much is a beer at the Navigation Bar?
Thanks for doing so much work to keep us entertained.
I have put in a ticket with vBulletin regarding the icons on the main forum homepage being pushed to the right as I can't find where to fix it, nor did I touch anything dealing with the forum home display templates.
Got to love security updates. :D
Like the Halloween Theme !!!
System Update *Complete*
