I have a 1000.2 with 3 lines running into a DP 44. I want to add a wing dish for 61.5, a cable from wing dish to the port # 4 of 1000.2 doesn't see the wing dish. Do I have to run a line down to the DP 44 ?
What is the least amount of signal needed to lock in?
If you only have a 722 and a 211 hooked up then why do you need a DPP 44 switch? If these are the only two boxes you have then remove the switch and connect wing dish to the 1000.4, run a switch test and you are done.
Apartment house setup just trying to add wing diah for football season. I'm on the edge of the spot beam to get my team in HD
