Will this work? wiring setup
agarrett22
SatelliteGuys Guru
145
Terre haute, IN
Will the following setup work?
dish 1000.4 WA -> dp34 -> dpp44 -> dual node?
wanting to hookup additional receiver to the dish but the 44 is full and about 100 foot from the dish, where i want to put the additional receiver is 15 ft from the dish. the additional receiver will be a 211k
Thanks in advance
I would put the DPP44 first and the DP34 second. Put the duo node on the DPP44 (ports 2-4, not behind the power inserter) and the other receiver(s) on the DP34. Just keep in mind with the DP34 you'll need two lines for dual tuner receivers.
I see you said 211k so DP vs DPP shouldn't matter in that case. You can try the DP34 first but I'm not sure how well that will work. I guess in theory it should work.
Could always get a DPP33 for 30 bucks.
Sent from my iPhone 4S using SatelliteGuys
dp34 before dpp44 did work, However not as I wanted it to as i forgot that the dp34 had to be powered to pass the signal on to the dpp44. Had to rethink my setup as I didn't plan on leaving a receiver attached to the dp34 all the time. O Well, At least it works.
Help...Please help. Installation question - Dish HD - no locals?
Google and Dish Network allegedly in talks for new wireless service
