Will 211K work on a sdtv?
Jonhern
511
Rhode Island
So we got a little problem, our DLP tv's bulb went out and we need to get a new one. We might not be able to get it right away so we are going to move one of the LCDs from a bedroom to the living room and a sdtv into that bedroom for a bit until we can get a new bulb. Wanted to be sure that it is ok to hook up the 211K into the SDTV. I believe it has component inputs.
Thanks.
Sure you can. The 211K has component, composite and s-video outputs. Use whatever your TV will handles and all will be fine.
I'm using a 411 to provide video to 3 tube style TVs and they work perfectly. I am using the RF output. But as "Bobby" said they have several outputs and you can pick what you need.
yeah, the component would not work, but the rf output does. The only way to get a clear picture with component was to set it to 480i but the color was still off and checked to make sure the wires were in correctly twice, so not sure why that happened but the rf is working fine.
January 1st is just around the corner!!
Help with two receivers
