spee12 said:super dish is for looking at 3 sats at the same time. you only need it if your locals are on 121 and others are on 119 and 110
tripod said:Actually,I have a duel lnb dish as a sprare and would like to get the"Pentagon" channel,which I already tested at 61.5,(AOK).Thought a superdish might pick it up.Guess Ill do without.
joshschuler said:You can't use a seperate dish for 105 or 121.
tripod said:"DUAL" was the correct spelling.Sorry Im not as educated as you.I have a dual Lnb that I picked up 61.5 on a one time basis only.I do not know what I would need as far as equipment(is the spelling ok?),switches,etc. to receive it all the time.I have a Dish 500,but cant determine manufacturer(spelled correctly?),all it has printed on it is'Dish digital Lnb.
TNGTony said:Chaddux, I think he wants to incorporate everything for seamless reception of 110/119/61.5 and possibly 105 or 121.
chaddux said:If you don't know what you're talking about, don't post. You just confuse the situation and people must come along and fix your errors. Confusing a newbie just compounds the issue. You're 100% wrong. You CAN use a separate dish for 105 or 121. You just can't use a small 18" dish. It must be 30" or bigger. You could have a DISH500 for 110/119 and a separate SuperDISH or compatible large dish to pick up 105 or 121. You can read some more details here. Is a Primestar dish a separate dish? Yup. Tony had already correctly addressed this issue. If you had read the entire thread, you would have seen it.
