While there certainly can be issues with the TVs connected to 622s (E* calls this "incompatibility"), the broken PCB connection problem is now well documented. For E* to essentially admit to the problem as they did in their Tech Chat in Aug., is proof-positive as far as I'm concerned. How much of the "no HDMI output" problem can be attributed to the broken PCB connections in relation to the other nonrelated root causes is anybody's guess, but I personally believe the PCB connection problem is a substantial percentage.shodobe said:I guess I am just lucky. No problems with my HDMI since March. Works perfectly with my Philips 50". I have a $14.99 Monoprice cable that works just great. I personally wonder if the problem doesn't exist mostly in the TV units and not in the 622. Just thinking out loud. It seems people are always itching to blame Dish for all the shortcomings of the 622 and not other things. I know there are alot of problems associated with the 622, believe me I know since my first unit went belly up with a burned out power supply!
Given the documented problem, you are well advised to take precautions to prevent excessive motion of the HDMI plug, and excessive weight of the cable(s) hanging from that plug. You have been lucky so far, but there is ample evidence that the broken connection problem can first evidence itself after several months of trouble-free operation.
I am not quick to blame E* for everything. Other than the no HDMI output problem in my first unit (actual cause was never determined) and the fact that I am underwhelmed by the OTA tuner performance (deep fringe area), I am otherwise quite pleased with the 622! YMMV...
